Command reference
vserver iscsi initiator show
Display iSCSI initiators currently connected
This command displays a list of active initiators currently connected to a specified Vserver.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Use this parameter to display the active initiators that match the Vserver that you specify.
[-tpgroup <text>] - Target Portal Group
Use this parameter to display the active initiators that match the name of the target portal group that you specify.
[-tsih <integer>] - Target Session ID
Use this parameter to display the active initiators that match the target session ID you that specify.
[-initiator-name <text>] - Initiator Name
Use this parameter to display the active initiators that match the initiator name that you specify.
[-initiator-alias <text>] - Initiator Alias
Use this parameter to display the active initiators that match the alias name that you specify.
[-tpgroup-tag <integer>] - TPGroup Tag
Use this parameter to display the active initiators that match the target portal group tag that you specify.
[-isid <text>] - Initiator Session ID
Use this parameter to display the active initiators that match the initiator session ID that you specify.
[-igroup <text>,…​] - Igroup Name
Use this parameter to display the active initiators that match the initiator group that you specify.
cluster1::> vserver iscsi initiator show -vserver vs_1
        Tpgroup       Initiator
Vserver Name     TSIH Name                  ISID              IGroup
vs_1    vs_1.iscsi  6 iqn.1994-05.com.redhat:6ed6dfb0489e
                                            00:02:3d:03:00:00 -
vs_1    vs_1.iscsi  7 iqn.1993-08.org.debian:01:fa752b8a5a3a
                                            00:02:3d:01:00:00 igroup_1
2 entries were displayed.
Displays the active initiator information on Vserver vs_1.
