vserver iscsi initiator show
Display iSCSI initiators currently connected
This command displays a list of active initiators currently connected to a specified Vserver.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver
Use this parameter to display the active initiators that match the Vserver that you specify.
- [-tpgroup <text>]- Target Portal Group
Use this parameter to display the active initiators that match the name of the target portal group that you specify.
- [-tsih <integer>]- Target Session ID
Use this parameter to display the active initiators that match the target session ID you that specify.
- [-initiator-name <text>]- Initiator Name
Use this parameter to display the active initiators that match the initiator name that you specify.
- [-initiator-alias <text>]- Initiator Alias
Use this parameter to display the active initiators that match the alias name that you specify.
- [-tpgroup-tag <integer>]- TPGroup Tag
Use this parameter to display the active initiators that match the target portal group tag that you specify.
- [-isid <text>]- Initiator Session ID
Use this parameter to display the active initiators that match the initiator session ID that you specify.
- [-igroup <text>,…]- Igroup Name
Use this parameter to display the active initiators that match the initiator group that you specify.
cluster1::> vserver iscsi initiator show -vserver vs_1
        Tpgroup       Initiator
Vserver Name     TSIH Name                  ISID              IGroup
vs_1    vs_1.iscsi  6 iqn.1994-05.com.redhat:6ed6dfb0489e
                                            00:02:3d:03:00:00 -
vs_1    vs_1.iscsi  7 iqn.1993-08.org.debian:01:fa752b8a5a3a
                                            00:02:3d:01:00:00 igroup_1
2 entries were displayed.
Displays the active initiator information on Vserver vs_1.
 PDFs
PDFs
