ONTAP commands
metrocluster check enable-periodic-check
Enable Periodic Check
The metrocluster check enable-periodic-check command enables the periodic checking of the MetroCluster configuration.
After this command is run, the MetroCluster Check job will able to run in the background and periodically check the configuration for errors.
clusA::> metrocluster check enable-periodic-check
