storage aggregate show-scrub-status
Display aggregate scrubbing status
The storage aggregate show-scrub-status
command displays the following information about the scrub status of aggregates:
Aggregate name
RAID groups
Whether the scrub is suspended
Percentage of the scrub that is completed
Last scrub time of the aggregate
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-aggregate <aggregate name>]
- Aggregate-
If this parameter is specified, the command displays detailed scrub-status information about the specified aggregate.
[-raidgroup <text>]
- RAID Group-
If this parameter is specified, the command displays information only about the aggregate that contains the specified RAID group.
[-node {<nodename>|local}]
- Node-
If this parameter is specified, the command displays information only about the aggregates on the specified node. The value
local
specifies the current node. [-suspended {true|false}]
- Is Suspended-
If this parameter is specified, the command displays information only about the aggregates that have the specified scrub-suspension state (true or false).
[-complete-percentage <percent>]
- Percentage Completed-
If this parameter is specified, the command displays information only about the aggregates whose scrubs have the specified completed percentage.
[-last-scrub-time <MM/DD/YYYY HH:MM:SS>]
- Last Scrub Time-
If this parameter is specified, the command displays information only about the aggregates that have the specified last-scrub time, in the format
MM/DD/YYYY HH:MM:SS
The following example displays scrub-status information for all the aggregates:
cluster1::> storage aggregate show-scrub-status Aggregate RAID Groups Suspended Percentage Last Scrub Time --------- ------------------- ---------- ---------- -------------------- aggr0 /aggr0/plex0/rg0 true 0% 3/31/2011 21:23:02 aggr1 /aggr1/plex0/rg1 true 45% 3/30/2011 01:05:00 aggr2 /aggr2/plex0/rg0 true 33% 3/30/2011 23:43:34 aggr3 /aggr3/plex0/rg1 true 79% 3/29/2011 00:34:36 4 entries were displayed.
The following example displays detailed information about the aggregate named aggr1:
cluster1::> storage aggregate show-scrub-status -instance -aggregate aggr1 Aggregate: aggr1 RAID Group: /aggr1/plex0/rg0 Is Suspended: false Percentage Completed: 2% Last Scrub Time: 3/31/2011 22:02:50
