storage aggregate show-scrub-status
Display aggregate scrubbing status
The storage aggregate show-scrub-status command displays the following information about the scrub status of aggregates:
Aggregate name
RAID groups
Whether the scrub is suspended
Percentage of the scrub that is completed
Last scrub time of the aggregate
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-aggregate <aggregate name>]- Aggregate
If this parameter is specified, the command displays detailed scrub-status information about the specified aggregate.
- [-raidgroup <text>]- RAID Group
If this parameter is specified, the command displays information only about the aggregate that contains the specified RAID group.
- [-node {<nodename>|local}]- Node
If this parameter is specified, the command displays information only about the aggregates on the specified node. The value localspecifies the current node.
- [-suspended {true|false}]- Is Suspended
If this parameter is specified, the command displays information only about the aggregates that have the specified scrub-suspension state (true or false).
- [-complete-percentage <percent>]- Percentage Completed
If this parameter is specified, the command displays information only about the aggregates whose scrubs have the specified completed percentage.
- [-last-scrub-time <MM/DD/YYYY HH:MM:SS>]- Last Scrub Time
If this parameter is specified, the command displays information only about the aggregates that have the specified last-scrub time, in the format MM/DD/YYYY HH:MM:SS.
The following example displays scrub-status information for all the aggregates:
cluster1::> storage aggregate show-scrub-status Aggregate RAID Groups Suspended Percentage Last Scrub Time --------- ------------------- ---------- ---------- -------------------- aggr0 /aggr0/plex0/rg0 true 0% 3/31/2011 21:23:02 aggr1 /aggr1/plex0/rg1 true 45% 3/30/2011 01:05:00 aggr2 /aggr2/plex0/rg0 true 33% 3/30/2011 23:43:34 aggr3 /aggr3/plex0/rg1 true 79% 3/29/2011 00:34:36 4 entries were displayed.
The following example displays detailed information about the aggregate named aggr1:
cluster1::> storage aggregate show-scrub-status -instance -aggregate aggr1
           Aggregate: aggr1
          RAID Group: /aggr1/plex0/rg0
        Is Suspended: false
Percentage Completed: 2%
     Last Scrub Time: 3/31/2011 22:02:50
 PDFs
PDFs
