ONTAP commands
vserver cifs nbtstat
Display NetBIOS information over TCP connection
The vserver cifs nbtstat command displays information about NetBIOS over TCP (NBT) connections for the cluster. It displays the IP address associated with the interfaces, the IP addresses of the WINS servers in use, and information about the registered NetBIOS names for the cluster. You can use this command to troubleshoot NetBIOS name resolution problems.
Note NetBIOS name service (NBNS) over IPv6 is not supported.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified node.
[-vserver <vserver name>] - Vserver
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified Vserver.
[-nbt-name <text>] - NBT Name
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified NetBIOS name.
[-netbios-suffix <Hex String>] - NetBIOS Suffix
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified NetBIOS suffix.
[-interface <IP Address>,…​] - Interfaces
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified IP address.
[-wins-servers <IP Address>,…​] - Servers
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified WINS servers.
[-server-state <text>,…​] - Server State (active, inactive)
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified WINS server state. The following are possible values for this parameter:
  • active
  • inactive
[-nbt-scope <text>] - NBT Scope
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified NetBIOS name scope.
[-nbt-mode <text>] - NBT Mode
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified NetBIOS name service mode. The following are possible values for this parameter:
  • 'p' - Point to Point
  • 'h' - Hybrid
  • 'm' - Mixed
  • 'b' - Broadcast
[-state <text>] - State
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified NetBIOS name registration state. The following are possible values for this parameter:
  • must_register
  • must_unregister
  • wins
  • broadcast
  • name_released
  • wins_conflict
  • broadcast_conflict
[-time-left <integer>] - Time Left
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified registration time left in minutes with the WINS server.
[-type <text>] - Type
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified name registration type. The following are possible values for this parameter:
  • registered
  • active
  • permanent
  • group
The following example displays the NetBIOS name service information.
cluster1::> nbtstat
          (vserver cifs nbtstat)
          Vserver: vs1
          Node:    cluster1-01
          Interfaces:
                   10.10.10.32
                   10.10.10.33
         Servers:
                   17.17.1.2  (active  )
         NBT Scope:
         NBT Mode:
                  [h]
         NBT Name           NetBIOS Suffix   State         Time Left     Type
         CLUSTER_1          00               wins          57
         CLUSTER_1          20               wins          57
Vserver: vs1
         Node:    cluster1-02
         Interfaces:
                 10.10.10.35
         Servers:
                 17.17.1.2  (active  )
         CLUSTER_1          00               wins          58
         CLUSTER_1          20               wins          58
         4 entries were displayed.
