vserver cifs group-policy central-access-rule show-defined
Show applicable central access rules defined in the Active Directory
The vserver cifs group-policy central-access-rule show-defined
command displays information about the central access rules that are defined in the Active Directory. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all CIFS servers:
Vserver name
Name of the central access rule
Creation time
Modification time
Current permissions
Proposed permissions
Target resources
[-fields <fieldname>,…]
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-instance ]
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only for central access rules for the specified Vserver.
[-name <TextNoCase>]
- Name-
If you specify this parameter, the command displays information only for central access rules that match the specified name.
[-description <text>]
- Description-
If you specify this parameter, the command displays information only for central access rules that match the specified description.
[-ctime <Date>]
- Creation Time-
If you specify this parameter, the command displays information only for central access rules that match the specified creation time.
[-mtime <Date>]
- Modification Time-
If you specify this parameter, the command displays information only for central access rules that match the specified modification time.
[-effective <text>]
- Effective Security Policy-
If you specify this parameter, the command displays information only for central access rules that match the specified effective security policy.
[-proposed <text>]
- Proposed Security Policy-
If you specify this parameter, the command displays information only for central access rules that match the specified proposed security policy.
[-resource <text>]
- Resource Condition-
If you specify this parameter, the command displays information only for central access rules that match the specified resource condition.
The following example displays information for all central access rules:
cluster1::> vserver cifs group-policy central-access-rule show-defined Vserver Name ---------- -------------------- vs1 r1 Description: rule #1 Creation Time: Tue Oct 22 09:33:48 2013 Modification Time: Tue Oct 22 09:33:48 2013 Current Permissions: O:SYG:SYD:AR(A;;FA;;;WD) Proposed Permissions: O:SYG:SYD:(A;;FA;;;OW)(A;;FA;;;BA)(A;;FA;;;SY) vs1 r2 Description: rule #2 Creation Time: Tue Oct 22 10:27:57 2013 Modification Time: Tue Oct 22 10:27:57 2013 Current Permissions: O:SYG:SYD:AR(A;;FA;;;WD) Proposed Permissions: O:SYG:SYD:(A;;FA;;;OW)(A;;FA;;;BA)(A;;FA;;;SY) 2 entries were displayed.
