Command reference
vserver cifs group-policy central-access-rule show-defined
Show applicable central access rules defined in the Active Directory
The vserver cifs group-policy central-access-rule show-defined command displays information about the central access rules that are defined in the Active Directory. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all CIFS servers:
  • Vserver name
  • Name of the central access rule
  • Description
  • Creation time
  • Modification time
  • Current permissions
  • Proposed permissions
  • Target resources
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>, …​ parameter, the command only displays the fields that you specify.
| [-instance ] }
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information only for central access rules for the specified Vserver.
[-name <TextNoCase>] - Name
If you specify this parameter, the command displays information only for central access rules that match the specified name.
[-description <text>] - Description
If you specify this parameter, the command displays information only for central access rules that match the specified description.
[-ctime <Date>] - Creation Time
If you specify this parameter, the command displays information only for central access rules that match the specified creation time.
[-mtime <Date>] - Modification Time
If you specify this parameter, the command displays information only for central access rules that match the specified modification time.
[-effective <text>] - Effective Security Policy
If you specify this parameter, the command displays information only for central access rules that match the specified effective security policy.
[-proposed <text>] - Proposed Security Policy
If you specify this parameter, the command displays information only for central access rules that match the specified proposed security policy.
[-resource <text>] - Resource Condition
If you specify this parameter, the command displays information only for central access rules that match the specified resource condition.
The following example displays information for all central access rules:
cluster1::> vserver cifs group-policy central-access-rule show-defined
Vserver    Name
vs1        r1
           Description: rule #1
         Creation Time: Tue Oct 22 09:33:48 2013
     Modification Time: Tue Oct 22 09:33:48 2013
   Current Permissions: O:SYG:SYD:AR(A;;FA;;;WD)
  Proposed Permissions: O:SYG:SYD:(A;;FA;;;OW)(A;;FA;;;BA)(A;;FA;;;SY)
vs1        r2
           Description: rule #2
         Creation Time: Tue Oct 22 10:27:57 2013
     Modification Time: Tue Oct 22 10:27:57 2013
2 entries were displayed.
