snapmirror show-history
Displays history of SnapMirror operations.
The snapmirror show-history command displays the history of the last 24 hours of SnapMirror operations. This command is not supported for relationships with non-Data ONTAP endpoints.
By default, the command displays the following information:
Destination Path
Source Path
Operation
Start Time
End Time
Result
The snapmirror show-history command displays - in reverse chronological order - the history of completed SnapMirror operations whose destination endpoints are in the current Vserver for Vserver administrators, or the current cluster for cluster administrators. This command does not return information on the following operations and relationships:
Operations that happened prior to installing Data ONTAP 8.3.
Relationships with the
"Relationship Capability"field, as shown in the output of the SnapMirror show command, set to"Pre 8.2". -
Operations on FlexGroup relationships that happened prior to installing Data ONTAP 9.5.
Operations on FlexGroup constituent relationships.
The -instance parameter displays the following detailed information:
Destination Path: Path of the destination endpoint.
Source Path: Path of the source endpoint.
Relationship ID: The unique identifier of the relationship.
This parameter is not supported for
Vserver SnapMirror relationships.
Relationship Group Type: For FlexVol relationships, specifies the
type of the group relationship that
includes this FlexVol. For group
relationships, specifies the type of the
group relationship. Can be one of the
following:
- none: No group relationship.
- vserver: Vserver relationship.
- flexgroup: FlexGroup relationship.
Operation: Type of the operation.
Can be one of the following:
- create
- modify
- quiesce
- resume
- delete
- initialize
- manual update
- scheduled update
- break
- resync
- abort
- restore
Operation ID: The unique identifier of the operation.
Start Time: Timestamp of the start of the operation.
End Time: Timestamp of the end of the operation.
Result: Result of the SnapMirror operation.
- success
- failure
Transfer Size: Total amount of data transferred during the
Additional Information: A message describing the cause of the
failure or additional information about a
successful operation, such as if a checkpoint
was cleared as part of an abort operation.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. - {
[-destination-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[cgname]>}]- Destination Path -
Select SnapMirror operations that have a matching destination path name.
[-destination-vserver <vserver name>]- Destination Vserver -
Select SnapMirror operations that have a matching destination Vserver name.
[-destination-volume <volume name>]- Destination Volume }-
Select SnapMirror operations that have a matching destination volume name.
[-operation-id <UUID>]- Operation ID-
Select SnapMirror operations that have a matching operation ID.
[-source-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[cgname]>}]- Source Path-
Select SnapMirror operations that have a matching source path name.
[-source-vserver <vserver name>]- Source Vserver-
Select SnapMirror operations that have a matching source Vserver name.
[-source-volume <volume name>]- Source Volume-
Select SnapMirror operations that have a matching source volume name.
[-operation-type {create|modify|quiesce|resume|delete|initialize|manual-update|scheduled-update|break|resync|abort|restore|failover}]- Operation Type-
Select SnapMirror operations that have a matching operation type. Possible values are:
create
modify
quiesce
resume
delete
initialize
manual-update
scheduled-update
break
resync
abort
restore
[-start-time <MM/DD/YYYY HH:MM:SS>]- Start Time-
Select SnapMirror operations that have a matching start time.
[-end-time <MM/DD/YYYY HH:MM:SS>]- End Time-
Select SnapMirror operations that have a matching end time.
[-relationship-id <UUID>]- Relationship ID-
Select SnapMirror operations that have a matching relationship ID.
[-relationship-group-type {none|vserver|consistencygroup|flexgroup|vserverflexgroup}]- Relationship Group Type-
Select SnapMirror relationships that have a matching relationship group type. Possible values are:
none
vserver
flexgroup
[-result {success|failure}]- Result of the Operation-
Select SnapMirror operations that have a matching result. Possible values are:
success
failure
[-transfer-size {<integer>[KB|MB|GB|TB|PB]}]- Transfer Size-
Select SnapMirror operations that have a matching transfer size.
[-additional-info <text>]- Additional Information-
Select SnapMirror operations that have matching additional information.
[-max-rows-per-relationship <integer>]- Maximum Number of Rows per Relationship-
Select a matching number of SnapMirror operations per relationship.
[-expand <true>]- Show Constituents of the Group.-
Select SnapMirror operations on relationships that are constituents and non-constituents of a group.
The example below displays summary information for all SnapMirror operations on relationships with destination endpoints in the current cluster:
cluster2::> snapmirror show-history
Destination Source Start End
Path Path Operation Time Time Result
dvs2: vs2: create 8/15/2013 08:22:23
8/15/2013 08:22:25
success
vs1:vol1 vs1:aggr1 manual-update
8/15/2013 08:22:44
8/15/2013 08:22:44
failure
vs1:vol1 vs1:aggr1 initialize
8/15/2013 08:22:25
8/15/2013 08:22:26
success
vs1:vol1 vs1:aggr1 create 8/15/2013 08:22:15
8/15/2013 08:22:16
success
vs1:vol2 vs1:aggr1 initialize
8/15/2013 08:23:23
8/15/2013 08:23:23
failure
vs1:vol2 vs1:aggr1 create 8/15/2013 08:23:10
8/15/2013 08:23:10
success
6 entries were displayed.
The example below displays detailed information for the SnapMirror operation with operation ID dc158715-0583-11e3-89bd-123478563412
cluster2::> snapmirror show-history -operation-id dc158715-0583-11e3-89bd-123478563412
Destination Path: vs1:vol1
Source Path: vs1:aggr1
Relationship ID: cb3d30a0-0583-11e3-89bd-123478563412
Relationship Group Type: none
Operation: manual-update
Operation ID: dc158715-0583-11e3-89bd-123478563412
Start Time: 8/15/2013 08:22:44
End Time: 8/15/2013 08:22:44
Result: failure
Transfer Size: -
Additional Information: Volume vs1:vol1 is restricted. Use the command "volume online" to bring the volume online.
The example below displays detailed information for all SnapMirror operations on relationships with the Result of "success" and whose destination endpoints are in the current cluster.
cluster2::> snapmirror show-history -result success -instance
Operation: initialize
Operation ID: d03ce1db-0583-11e3-89bd-123478563412
Start Time: 8/15/2013 08:22:25
End Time: 8/15/2013 08:22:26
Result: success
Transfer Size: 1.09MB
Additional Information: -
Operation: create
Operation ID: cb3d305d-0583-11e3-89bd-123478563412
Start Time: 8/15/2013 08:22:15
End Time: 8/15/2013 08:22:16
Result: success
Transfer Size: -
Destination Path: vs1:vol2
Relationship ID: eb92c549-0583-11e3-89bd-123478563412
Operation: create
Operation ID: eb92c506-0583-11e3-89bd-123478563412
Start Time: 8/15/2013 08:23:10
End Time: 8/15/2013 08:23:10
Result: success
Transfer Size: -
3 entries were displayed.
The example below displays summary information for all SnapMirror operations on relationships with max-rows-per-relationship of 1 and whose destination endpoints are in the current cluster.
cluster2::> snapmirror show-history -max-rows-per-relationship 1
8/15/2013 08:22:44
8/15/2013 08:22:44
failure
8/15/2013 08:23:23
8/15/2013 08:23:23
failure
2 entries were displayed.
