ONTAP commands
snapmirror show-history
Displays history of SnapMirror operations.
The snapmirror show-history command displays the history of the last 24 hours of SnapMirror operations. This command is not supported for relationships with non-ONTAP endpoints.
By default, the command displays the following information:
  • Destination Path
  • Source Path
  • Operation
  • Start Time
  • End Time
  • Result
The snapmirror show-history command displays - in reverse chronological order - the history of completed SnapMirror operations whose destination endpoints are in the current Vserver for Vserver administrators, or the current cluster for cluster administrators. This command does not return information on the following operations and relationships:
  • Operations that happened prior to installing ONTAP 8.3.
  • Relationships with the "Relationship Capability" field, as shown in the output of the SnapMirror show command, set to "Pre 8.2" .
  • Operations on FlexGroup relationships that happened prior to installing ONTAP 9.5.
  • Operations on FlexGroup constituent relationships.
The -instance parameter displays the following detailed information:
             Destination Path: Path of the destination endpoint.
                  Source Path: Path of the source endpoint.
              Relationship ID: The unique identifier of the relationship.
                               This parameter is not supported for
                               Vserver SnapMirror relationships.
      Relationship Group Type: For FlexVol relationships, specifies the
                               type of the group relationship that
                               includes this FlexVol. For group
                               relationships, specifies the type of the
                               group relationship. Can be one of the
                               following:
                               - none: No group relationship.
                               - vserver: Vserver relationship.
                               - flexgroup: FlexGroup relationship.
                    Operation: Type of the operation.
                               Can be one of the following:
                               - create
                               - modify
                               - quiesce
                               - resume
                               - delete
                               - initialize
                               - manual update
                               - scheduled update
                               - break
                               - resync
                               - abort
                               - restore
                 Operation ID: The unique identifier of the operation.
                   Start Time: Timestamp of the start of the operation.
                     End Time: Timestamp of the end of the operation.
                       Result: Result of the SnapMirror operation.
                               - success
                               - failure
                Transfer Size: Total amount of data transferred during the
       Additional Information: A message describing the cause of the
                               failure or additional information about a
                               successful operation, such as if a checkpoint
                               was cleared as part of an abort operation.
{ [-fields <fieldname>,…​]
| [-instance ] }
{ [-destination-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}] - Destination Path
| [-destination-vserver <vserver name>] - Destination Vserver
Select SnapMirror operations that have a matching destination Vserver name.
[-destination-volume <volume name>] - Destination Volume }
Select SnapMirror operations that have a matching destination volume name.
[-operation-id <UUID>] - Operation ID
Select SnapMirror operations that have a matching operation ID.
[-source-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}] - Source Path
[-source-vserver <vserver name>] - Source Vserver
Select SnapMirror operations that have a matching source Vserver name.
[-source-volume <volume name>] - Source Volume
Select SnapMirror operations that have a matching source volume name.
[-operation-type {create|modify|quiesce|resume|delete|initialize|manual-update|scheduled-update|break|resync|abort|restore|failover|rsetup|baseline-gather}] - Operation Type
Select SnapMirror operations that have a matching operation type. Possible values are:
  • create
  • modify
  • quiesce
  • resume
  • delete
  • initialize
  • manual-update
  • scheduled-update
  • break
  • resync
  • abort
  • restore
[-start-time <MM/DD/YYYY HH:MM:SS>] - Start Time
Select SnapMirror operations that have a matching start time.
[-end-time <MM/DD/YYYY HH:MM:SS>] - End Time
Select SnapMirror operations that have a matching end time.
[-relationship-id <UUID>] - Relationship ID
Select SnapMirror operations that have a matching relationship ID.
[-relationship-group-type {none|vserver|consistencygroup|flexgroup|vserverflexgroup|vserverconsistencygroup}] - Relationship Group Type
Select SnapMirror relationships that have a matching relationship group type. Possible values are:
  • none
  • vserver
  • flexgroup
[-result {success|failure}] - Result of the Operation
Select SnapMirror operations that have a matching result. Possible values are:
  • success
  • failure
[-transfer-size {<integer>[KB|MB|GB|TB|PB]}] - Transfer Size
Select SnapMirror operations that have a matching transfer size.
[-additional-info <text>] - Additional Information
Select SnapMirror operations that have matching additional information.
[-max-rows-per-relationship <integer>] - Maximum Number of Rows per Relationship
Select a matching number of SnapMirror operations per relationship.
[-expand <true>] - Show Constituents of the Group.
Select SnapMirror operations on relationships that are constituents and non-constituents of a group.
The example below displays summary information for all SnapMirror operations on relationships between Consistency Groups with destination endpoints in the current cluster:
cluster2::> snapmirror show-history
Destination Source                Start       End
Path        Path        Operation Time        Time        Result
svm2:/cg/cg1_dst
            svm1:/cg/cg1
                        manual-update
                                  10/10/2024 01:01:17
                                              10/10/2024 01:10:40
                                                          success
svm2:/cg/cg1_dst
            svm1:/cg/cg1
                        initialize
                                  10/9/2024 13:53:16
                                              10/9/2024 13:55:49
                                                          success
svm2:/cg/cg1_dst
            svm1:/cg/cg1
                        create    10/9/2024 13:52:40
                                              10/9/2024 13:52:44
                                                          success
3 entries were displayed.
