ONTAP commands
system services ndmp service show
Display NDMP service configuration
The system services ndmp service show command displays the following information about the NDMP service configuration across all the nodes in the cluster:
  • Node name
  • NDMP Common Sessions
A combination of parameters can be optionally supplied to filter the results based on specific criteria.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node (privilege: advanced)
Selects information about the specified node.
[-common-sessions <integer>] - NDMP Common Sessions (privilege: advanced)
Selects information about the nodes that have the specified number of NDMP common sessions.
The following example displays information about the NDMP configuration of all nodes in the cluster:
cluster1::> system services ndmp service show
Node        Common Sessions
node0                    16
node1                    16
node2                    16
node3                    16
4 entries were displayed.
