system services ndmp service show
Display NDMP service configuration
The system services ndmp service show command displays the following information about the NDMP service configuration across all the nodes in the cluster:
Node name
NDMP Common Sessions
A combination of parameters can be optionally supplied to filter the results based on specific criteria.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node (privilege: advanced)
Selects information about the specified node.
- [-common-sessions <integer>]- NDMP Common Sessions (privilege: advanced)
Selects information about the nodes that have the specified number of NDMP common sessions.
The following example displays information about the NDMP configuration of all nodes in the cluster:
cluster1::> system services ndmp service show Node Common Sessions ----------- --------------- node0 16 node1 16 node2 16 node3 16 4 entries were displayed.
 PDFs
PDFs
