vserver audit rotate-log
Rotate audit log
The vserver audit rotate-log
command rotates audit logs for a Vserver.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver for which audit logs are to be rotated. The Vserver audit configuration must already exist. Auditing must be enabled for the Vserver.
The following example rotates audit logs for Vserver vs1.
cluster1::> vserver audit rotate-log -vserver vs1
