vserver vscan on-access-policy file-ext-to-exclude add
Add to the list of file extensions to exclude
The vserver vscan on-access-policy file-ext-to-exclude add
command adds a file extension or a list of file extensions that must be excluded from scanning to the specified policy name.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver containing the specified on-access policy to which you want to add a file extension or a list of file extensions that must be excluded from scanning.
-policy-name <Policy name>
- Policy-
This parameter specifies the name of the on-access policy to which you want to add a file extension or a list of file extensions that must be excluded from scanning.
-file-ext-to-exclude <File extension>,…
- File Extensions Not to Scan-
This parameter specifies the file extension or a list of file extensions that must be excluded from scanning.
The following example adds a list of file extensions that must be excluded from scanning to the specified on-access policy:
cluster1::> vserver vscan on-access-policy file-ext-to-exclude add -vserver vs1 -policy-name policy1 -file-ext-to-exclude txt,mp4 cluster1::> vserver vscan on-access-policy file-ext-to-exclude show -vserver vs1 -policy-name policy1 Vserver: vs1 Policy: policy1 File-Extensions Not to Scan: mp3, mp4, txt, wav
