ONTAP commands
vserver vscan on-access-policy file-ext-to-exclude add
Add to the list of file extensions to exclude
The vserver vscan on-access-policy file-ext-to-exclude add command adds a file extension or a list of file extensions that must be excluded from scanning to the specified policy name.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver containing the specified on-access policy to which you want to add a file extension or a list of file extensions that must be excluded from scanning.
-policy-name <Policy name> - Policy
This parameter specifies the name of the on-access policy to which you want to add a file extension or a list of file extensions that must be excluded from scanning.
-file-ext-to-exclude <File extension>,…​ - File Extensions Not to Scan
This parameter specifies the file extension or a list of file extensions that must be excluded from scanning.
The following example adds a list of file extensions that must be excluded from scanning to the specified on-access policy:
cluster1::> vserver vscan on-access-policy file-ext-to-exclude add -vserver vs1
            -policy-name policy1 -file-ext-to-exclude txt,mp4
cluster1::> vserver vscan on-access-policy file-ext-to-exclude show -vserver vs1
Vserver: vs1
                     Policy: policy1
File-Extensions Not to Scan: mp3, mp4, txt, wav
