security certificate rename
Rename a certificate
This command allows the user to modify the name of an installed digital certificate. This command does not alter the certificate itself.
-vserver <Vserver Name>
- Vserver Name-
This specifies the name of the Vserver on which the certificate exists.
-cert-name <text>
- Existing Certificate Name-
This specifies the current name of the certificate.
-new-name <text>
- New Certificate Name-
This specifies the desired name of the certificate. It must be unique among certificates in the Vserver.
cluster1::> security certificate rename -vserver vs0 -cert-name AAACertificateServices -new-nameAAACertServ
