ONTAP commands
security certificate rename
Rename a certificate
This command allows the user to modify the name of an installed digital certificate. This command does not alter the certificate itself.
-vserver <Vserver Name> - Vserver Name
This specifies the name of the Vserver on which the certificate exists.
-cert-name <text> - Existing Certificate Name
This specifies the current name of the certificate.
-new-name <text> - New Certificate Name
This specifies the desired name of the certificate. It must be unique among certificates in the Vserver.
cluster1::> security certificate rename -vserver vs0 -cert-name AAACertificateServices -new-nameAAACertServ
