volume file clone deletion show
PDF of this doc site
Creating your file...
Show the supported file extensions for clone delete
The volume file clone deletion show
command displays the following information for clone delete:
Vserver Name
Volume Name
Minimum File Size Required for Clone Delete
List of Supported File Extensions for Clone Delete
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name-
Name of the vserver.
[-volume <volume name>]
- Volume Name-
Name of the volume.
[-extensions <text>,…]
- Supported Extensions for Clone Delete-
List of supported file extensions for Clone Delete.
[-minimum-size {<integer>[KB|MB|GB|TB|PB]}]
- Minimum Size Required for Clone delete-
Minimum file size required for Clone Delete.
The following example displays the clone deletion information for all volumes of all vservers.
cluster1::> volume file clone deletion show Vserver Volume Minimum Extensions Size ----------------- ------------------- ------- ---------------------- vs0 testvol 100B vmdk, vhd, vhdx, vswp vs0_root 0B - vs1 testvol 100G vmdk, vhd, vhdx, vswp vs1_root 0B -
The following example displays the clone deletion information for volume vol1
of vserver vs1
cluster1::> volume file clone deletion show -vserver vs0 -volume testvol Vserver Name: vs0 Volume Name: testvol Supported Extensions for Clone Delete: vmdk, vhd, vhdx, vswp Minimum Size Required for Clone delete: 100B
