volume file clone deletion show
Show the supported file extensions for clone delete
The volume file clone deletion show command displays the following information for clone delete:
Vserver Name
Volume Name
Minimum File Size Required for Clone Delete
List of Supported File Extensions for Clone Delete
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
Name of the vserver.
[-volume <volume name>]- Volume Name-
Name of the volume.
[-extensions <text>,…]- Supported Extensions for Clone Delete-
List of supported file extensions for Clone Delete.
[-minimum-size {<integer>[KB|MB|GB|TB|PB]}]- Minimum Size Required for Clone delete-
Minimum file size required for Clone Delete.
The following example displays the clone deletion information for all volumes of all vservers.
cluster1::> volume file clone deletion show
Vserver Volume Minimum Extensions
Size
vs0 testvol 100B vmdk, vhd, vhdx, vswp
vs0_root 0B -
vs1 testvol 100G vmdk, vhd, vhdx, vswp
vs1_root 0B -
The following example displays the clone deletion information for volume vol1 of vserver vs1 .
cluster1::> volume file clone deletion show -vserver vs0 -volume testvol
Vserver Name: vs0
Volume Name: testvol
Supported Extensions for Clone Delete: vmdk, vhd, vhdx, vswp
Minimum Size Required for Clone delete: 100B
