Command reference
volume file clone deletion show
Show the supported file extensions for clone delete
The volume file clone deletion show command displays the following information for clone delete:
  • Vserver Name
  • Volume Name
  • Minimum File Size Required for Clone Delete
  • List of Supported File Extensions for Clone Delete
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
Name of the vserver.
[-volume <volume name>] - Volume Name
Name of the volume.
[-extensions <text>,…​] - Supported Extensions for Clone Delete
List of supported file extensions for Clone Delete.
[-minimum-size {<integer>[KB|MB|GB|TB|PB]}] - Minimum Size Required for Clone delete
Minimum file size required for Clone Delete.
The following example displays the clone deletion information for all volumes of all vservers.
cluster1::> volume file clone deletion show
        Vserver            Volume                Minimum    Extensions
                                                    Size
       vs0                 testvol                 100B      vmdk, vhd, vhdx, vswp
                           vs0_root                  0B      -
       vs1                 testvol                 100G      vmdk, vhd, vhdx, vswp
                           vs1_root                  0B      -
The following example displays the clone deletion information for volume vol1 of vserver vs1 .
cluster1::> volume file clone deletion show -vserver vs0 -volume testvol
                          Vserver Name: vs0
                           Volume Name: testvol
 Supported Extensions for Clone Delete: vmdk, vhd, vhdx, vswp
Minimum Size Required for Clone delete: 100B
