security login motd show
Display the message of the day
The security login motd show
command displays information about the cluster-level and data Vserver clustershell message of the day (MOTD).
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Selects the message of the day entries that match this parameter value. Use the name of the cluster admin Vserver to see the cluster-level MOTD.
[-message <text>]
- Message of the Day (MOTD)-
[-is-cluster-message-enabled {true|false}]
- Is Cluster-level Message Enabled?-
The following example displays all message of the day entries:
cluster1::> security login motd show Vserver: cluster1 Is the Cluster MOTD Displayed?: true Message ----------------------------------------------------------------------------- The cluster is running normally. Vserver: vs0 Is the Cluster MOTD Displayed?: true Message ----------------------------------------------------------------------------- Welcome to the Vserver! 2 entries were displayed.
