ONTAP commands
security login motd show
Display the message of the day
The security login motd show command displays information about the cluster-level and data Vserver clustershell message of the day (MOTD).
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Selects the message of the day entries that match this parameter value. Use the name of the cluster admin Vserver to see the cluster-level MOTD.
[-message <text>] - Message of the Day (MOTD)
[-is-cluster-message-enabled {true|false}] - Is Cluster-level Message Enabled?
The following example displays all message of the day entries:
cluster1::> security login motd show
Vserver: cluster1
Is the Cluster MOTD Displayed?: true
Message
The cluster is running normally.
Vserver: vs0
Message
Welcome to the Vserver!
2 entries were displayed.
