      vserver nfs pnfs devices cache show
Display the device cache
The `vserver nfs pnfs devices cache show` command displays the device cache.
[-fields <fieldname>,…] -
If you specify the
-fieldsparameter, the command only displays the fields that you specify. - |
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all entries. [-node {<nodename>|local}]- Node (privilege: advanced)-
If you specify this parameter, the command displays information only about the pNFS devices cache present on the node.
 [-vserver <vserver name>]- Vserver Name (privilege: advanced)-
If you specify this parameter, the command displays information only about the Vserver that has the pNFS devices cache.
