vserver cifs group-policy update
Apply group policy settings defined in Active Directory
The vserver cifs group-policy update command applies the group-policy settings defined in Active Directory for the given Vserver. This command is not supported for workgroup CIFS servers.
-vserver <vserver name> - Vserver Name
This parameter specifies the CIFS-enabled Vserver to which the group-policy settings be applied.
[-force-reapply-all-settings {true|false}] - Force Re-apply All Settings
This parameter specifies whether to ignore all processing optimizations and re-apply all settings. The default is false.
The following example applies the group-policy settings defined in Active Directory for Vserver vs1.
cluster1::> vserver cifs group-policy update -vserver vs1 -force-reapply-all-settings true
