vserver services web access create
Authorize a new role for web service access
This command authorizes roles to access the Vserver’s web services. For the user to access services that require authentication, the user’s roles, as defined by security login show , must be included in this configuration.
Node Vserver services are authorized with the data Vserver’s roles. |
-vserver <Vserver Name>
- Vserver-
Identifies a Vserver for hosting a specific web service.
-name <text>
- Service Name-
Identifies the name of the web service.
-role <text>
- Role Name-
Identifies the new role to be authorized for this service.
The following example authorizes the role auditor
- created previously - for the web service:
cluster1::> vserver services web access create -name ontapi -role auditor
