security login show
Show user login methods
The security login show
command displays the following information about user login methods:
User name
Application (amqp, console, http, ontapi, rsh, snmp, service-processor, ssh, or telnet)
Authentication method (community, password, publickey, or usm)
Role name
Whether the account is locked
Whether the user name refers to
nsswitch
group -
Password hash function
LDAP fastbind authentication
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
Displays the login methods that match the specified Vserver name.
[-user-or-group-name <text>]
- User Name or Group Name-
Displays the login methods that match this parameter value. Value can be a user name or Active Directory, LDAP, or NIS group name.
[-application <text>]
- Application-
Displays the login methods that match the specified application type. Possible values include amqp, console, http, ontapi, rsh, snmp, service-processor, ssh, and telnet.
[-authentication-method <text>]
- Authentication Method-
Displays the login methods that match the specified authentication method. Possible values include the following:
cert - SSL certificate authentication
community - SNMP community strings
domain - Active Directory authentication
nsswitch - LDAP or NIS authentication
password - Password
publickey - Public-key authentication
usm - SNMP user security model
saml - SAML authentication
[-remote-switch-ipaddress <IP Address>]
- Remote Switch IP Address-
Displays the login methods that match the specified IP address of the remote switch. The remote switch could be a cluster switch monitored by cluster switch health monitor (CSHM) or a Fibre Channel (FC) switch monitored by MetroCluster health monitor (MCC-HM). This parameter is applicable only when the application is
snmp
and authentication method isusm
(SNMP user security model). [-role <text>]
- Role Name-
Displays the login methods that match the specified role.
[-is-account-locked {yes|no}]
- Account Locked-
Displays the login methods that match the specified account lock status.
[-comment <text>]
- Comment Text-
Displays the login methods that match the specified comment text.
[-is-ns-switch-group {yes|no}]
- Whether Ns-switch Group-
This specifies whether
user-or-group-name
is an LDAP or NIS group. Possible values are yes or no. [-hash-function {sha512|sha256}]
- Password Hash Function-
Displays the login methods that match the specified password-hashing algorithm. Possible values are:
sha512 - Secure hash algorithm (512 bits)
sha256 - Secure hash algorithm (256 bits)
md5 - Message digest algorithm (128 bits)
[-second-authentication-method {none|publickey|password|nsswitch}]
- Second Authentication Method2-
Displays the login methods that match the specified authentication method to be used as the second factor. Possible values include the following:
password - Password
nsswitch - NIS or LDAP authentication
none - default value
[-is-ldap-fastbind {yes|no}]
- LDAP Fastbind Authentication-
Displays the authentication methods that are LDAP fastbind.
The example below illustrates how to display information about all user login methods:
cluster1::> security login show Vserver: cluster1 Second User/Group Authentication Acct Authentication Name Application Method Role Name Locked Method -------------- ----------- ------------- ---------------- ------ -------------- admin amqp password admin no none admin console password admin no none admin http password admin no none admin ontapi password admin no none admin service-processor password admin no none admin ssh password admin no none autosupport console password autosupport no none Vserver: vs1.netapp.com Second User/Group Authentication Acct Authentication Name Application Method Role Name Locked Method -------------- ----------- ------------- ---------------- ------ -------------- vsadmin http password vsadmin yes none vsadmin ontapi password vsadmin yes none vsadmin ssh password vsadmin yes none 9 entries were displayed.
