security login show
Show user login methods
The security login show command displays the following information about user login methods:
User name
Application (amqp, console, http, ontapi, rsh, snmp, service-processor, ssh, or telnet)
Authentication method (community, password, publickey, or usm)
Role name
Whether the account is locked
Whether the user name refers to
nsswitchgroup -
Password hash function
LDAP fastbind authentication
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
Displays the login methods that match the specified Vserver name.
 [-user-or-group-name <text>]- User Name or Group Name-
Displays the login methods that match this parameter value. Value can be a user name or Active Directory, LDAP, or NIS group name.
 [-application <text>]- Application-
Displays the login methods that match the specified application type. Possible values include amqp, console, http, ontapi, rsh, snmp, service-processor, ssh, and telnet.
 [-authentication-method <text>]- Authentication Method-
Displays the login methods that match the specified authentication method. Possible values include the following:
cert - SSL certificate authentication
community - SNMP community strings
domain - Active Directory authentication
nsswitch - LDAP or NIS authentication
password - Password
publickey - Public-key authentication
usm - SNMP user security model
saml - SAML authentication
 [-remote-switch-ipaddress <IP Address>]- Remote Switch IP Address-
Displays the login methods that match the specified IP address of the remote switch. The remote switch could be a cluster switch monitored by cluster switch health monitor (CSHM) or a Fibre Channel (FC) switch monitored by MetroCluster health monitor (MCC-HM). This parameter is applicable only when the application is
snmpand authentication method isusm(SNMP user security model). [-role <text>]- Role Name-
Displays the login methods that match the specified role.
 [-is-account-locked {yes|no}]- Account Locked-
Displays the login methods that match the specified account lock status.
 [-comment <text>]- Comment Text-
Displays the login methods that match the specified comment text.
 [-is-ns-switch-group {yes|no}]- Whether Ns-switch Group-
This specifies whether
user-or-group-nameis an LDAP or NIS group. Possible values are yes or no. [-hash-function {sha512|sha256}]- Password Hash Function (privilege: advanced)-
Displays the login methods that match the specified password-hashing algorithm. Possible values are:
sha512 - Secure hash algorithm (512 bits)
sha256 - Secure hash algorithm (256 bits)
md5 - Message digest algorithm (128 bits)
 [-second-authentication-method {none|publickey|password|nsswitch|domain|totp}]- Second Authentication Method2-
Displays the login methods that match the specified authentication method to be used as the second factor. Possible values include the following:
password - Password
nsswitch - NIS or LDAP authentication
none - default value
 [-is-ldap-fastbind {yes|no}]- LDAP Fastbind Authentication-
Displays the authentication methods that are LDAP fastbind.
The example below illustrates how to display information about all user login methods:
cluster1::> security login show
Vserver: cluster1
        Second
User/Group                 Authentication                 Acct   Authentication
Name           Application Method        Role Name        Locked Method
admin          amqp        password      admin            no     none
admin          console     password      admin            no     none
admin          http        password      admin            no     none
admin          ontapi      password      admin            no     none
admin          service-processor
admin          ssh         password      admin            no     none
autosupport    console     password      autosupport      no     none
user1          ssh         publickey     admin            -      none
user2          ssh         password      admin            no     publickey
Vserver: vs1.netapp.com
        Second
vsadmin        http        password      vsadmin          yes    none
vsadmin        ontapi      password      vsadmin          yes    none
vsadmin        ssh         password      vsadmin          yes    none
12 entries were displayed.
