ONTAP commands
security login show
Show user login methods
The security login show command displays the following information about user login methods:
  • User name
  • Application (amqp, console, http, ontapi, rsh, snmp, service-processor, ssh, or telnet)
  • Authentication method (community, password, publickey, or usm)
  • Role name
  • Whether the account is locked
  • Whether the user name refers to nsswitch group
  • Password hash function
  • LDAP fastbind authentication
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
Displays the login methods that match the specified Vserver name.
[-user-or-group-name <text>] - User Name or Group Name
Displays the login methods that match this parameter value. Value can be a user name or Active Directory, LDAP, or NIS group name.
[-application <text>] - Application
Displays the login methods that match the specified application type. Possible values include amqp, console, http, ontapi, rsh, snmp, service-processor, ssh, and telnet.
[-authentication-method <text>] - Authentication Method
Displays the login methods that match the specified authentication method. Possible values include the following:
  • cert - SSL certificate authentication
  • community - SNMP community strings
  • domain - Active Directory authentication
  • nsswitch - LDAP or NIS authentication
  • password - Password
  • publickey - Public-key authentication
  • usm - SNMP user security model
  • saml - SAML authentication
[-remote-switch-ipaddress <IP Address>] - Remote Switch IP Address
Displays the login methods that match the specified IP address of the remote switch. The remote switch could be a cluster switch monitored by cluster switch health monitor (CSHM) or a Fibre Channel (FC) switch monitored by MetroCluster health monitor (MCC-HM). This parameter is applicable only when the application is snmp and authentication method is usm (SNMP user security model).
[-role <text>] - Role Name
Displays the login methods that match the specified role.
[-is-account-locked {yes|no}] - Account Locked
Displays the login methods that match the specified account lock status.
[-comment <text>] - Comment Text
Displays the login methods that match the specified comment text.
[-is-ns-switch-group {yes|no}] - Whether Ns-switch Group
This specifies whether user-or-group-name is an LDAP or NIS group. Possible values are yes or no.
[-hash-function {sha512|sha256}] - Password Hash Function (privilege: advanced)
Displays the login methods that match the specified password-hashing algorithm. Possible values are:
  • sha512 - Secure hash algorithm (512 bits)
  • sha256 - Secure hash algorithm (256 bits)
  • md5 - Message digest algorithm (128 bits)
[-second-authentication-method {none|publickey|password|nsswitch|domain|totp}] - Second Authentication Method
Displays the login methods that match the specified authentication method to be used as the second factor. Presently, ssh , http and service-processor are the only applications supporting a second factor of authentication. For ssh application, possible values include the following:
  • nsswitch - NIS or LDAP authentication
  • totp - TOTP authentication
  • none - default value
For the http and service-processor applications, possible values include the following:
[-is-ldap-fastbind {yes|no}] - LDAP Fastbind Authentication
Displays the authentication methods that are LDAP fastbind.
The example below illustrates how to display information about all user login methods:
cluster1::> security login show
Vserver: cluster1
        Second
User/Group                 Authentication                 Acct   Authentication
Name           Application Method        Role Name        Locked Method
admin          amqp        password      admin            no     none
admin          console     password      admin            no     none
admin          http        password      admin            no     none
admin          ontapi      password      admin            no     none
admin          service-processor
admin          ssh         password      admin            no     none
autosupport    console     password      autosupport      no     none
user1          ssh         publickey     admin            -      none
user2          ssh         password      admin            no     publickey
spuser         service-processor
Vserver: vs1.netapp.com
        Second
vsadmin        http        password      vsadmin          yes    none
vsadmin        ontapi      password      vsadmin          yes    none
vsadmin        ssh         password      vsadmin          yes    none
12 entries were displayed.
