security login show
Show user login methods
The security login show command displays the following information about user login methods:
User name
Application (amqp, console, http, ontapi, rsh, snmp, service-processor, ssh, or telnet)
Authentication method (community, password, publickey, or usm)
Role name
Whether the account is locked
Whether the user name refers to
nsswitchgroup -
Password hash function
LDAP fastbind authentication
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
Displays the login methods that match the specified Vserver name.
[-user-or-group-name <text>]- User Name or Group Name-
Displays the login methods that match this parameter value. Value can be a user name or Active Directory, LDAP, or NIS group name.
[-application <text>]- Application-
Displays the login methods that match the specified application type. Possible values include amqp, console, http, ontapi, rsh, snmp, service-processor, ssh, and telnet.
[-authentication-method <text>]- Authentication Method-
Displays the login methods that match the specified authentication method. Possible values include the following:
cert - SSL certificate authentication
community - SNMP community strings
domain - Active Directory authentication
nsswitch - LDAP or NIS authentication
password - Password
publickey - Public-key authentication
usm - SNMP user security model
saml - SAML authentication
[-remote-switch-ipaddress <IP Address>]- Remote Switch IP Address-
Displays the login methods that match the specified IP address of the remote switch. The remote switch could be a cluster switch monitored by cluster switch health monitor (CSHM) or a Fibre Channel (FC) switch monitored by MetroCluster health monitor (MCC-HM). This parameter is applicable only when the application is
snmpand authentication method isusm(SNMP user security model). [-role <text>]- Role Name-
Displays the login methods that match the specified role.
[-is-account-locked {yes|no}]- Account Locked-
Displays the login methods that match the specified account lock status.
[-comment <text>]- Comment Text-
Displays the login methods that match the specified comment text.
[-is-ns-switch-group {yes|no}]- Whether Ns-switch Group-
This specifies whether
user-or-group-nameis an LDAP or NIS group. Possible values are yes or no. [-hash-function {sha512|sha256}]- Password Hash Function (privilege: advanced)-
Displays the login methods that match the specified password-hashing algorithm. Possible values are:
sha512 - Secure hash algorithm (512 bits)
sha256 - Secure hash algorithm (256 bits)
md5 - Message digest algorithm (128 bits)
[-second-authentication-method {none|publickey|password|nsswitch|domain|totp}]- Second Authentication Method2-
Displays the login methods that match the specified authentication method to be used as the second factor. Presently,
sshandservice-processorare the only applications supporting a second factor of authentication. Forsshapplication, possible values include the following:-
password - Password
nsswitch - NIS or LDAP authentication
none - default value
For
service-processorapplication, possible values include the following:
[-is-ldap-fastbind {yes|no}]- LDAP Fastbind Authentication-
Displays the authentication methods that are LDAP fastbind.
The example below illustrates how to display information about all user login methods:
cluster1::> security login show
Vserver: cluster1
Second
User/Group Authentication Acct Authentication
Name Application Method Role Name Locked Method
admin amqp password admin no none
admin console password admin no none
admin http password admin no none
admin ontapi password admin no none
admin service-processor
admin ssh password admin no none
autosupport console password autosupport no none
user1 ssh publickey admin - none
user2 ssh password admin no publickey
spuser service-processor
Vserver: vs1.netapp.com
Second
vsadmin http password vsadmin yes none
vsadmin ontapi password vsadmin yes none
vsadmin ssh password vsadmin yes none
12 entries were displayed.
