security anti-ransomware volume show
Show anti-ransomware related information of volumes
The security anti-ransomware volume show command displays information related to Anti-ransomware on the volumes in the cluster. The following information is displayed:
Vserver Name: The Vserver on which the volume is located.
Volume Name: The volume name
State: The Anti-ransomware state of the volume. The possible values are
disabled,enabled,dry-run,dry-run-paused,enable-pausedanddisable-in-progress.
[-fields <fieldname>,…] -
If you specify the
[-attack ] -
If this parameter is specified, ransomware attack details are displayed.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
If this parameter and the
-volumeparameter are specified, the command displays detailed information related to Anti-ransomware about the specified volume. If this parameter is specified by itself, the command displays information related to the Anti-ransomware about all volumes on the specified Vservee. [-volume <volume name>]- Volume Name-
-vserverparameter are specified, the command displays detailed information related to Anti-ransomware about the specified volume. If this parameter is specified by itself, the command displays information related to the Anti-ransomware about all volumes matching the specified name. [-state {disabled|enabled|dry-run|paused|dry-run-paused|enable-paused|disable-in-progress}]- State-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified Anti-ransomware state. The possible values are
disabled,enabled,dry-run,dry-run-paused,enable-pausedanddisable-in-progress. The possible states are:-
disabled - Anti-ransomware is disabled on the volume.
enabled - Anti-ransomware is enabled on the volume.
dry-run - Anti-ransomware is enabled in the dry-run or evaluation mode on the volume.
dry-run-paused - Anti-ransomware is paused from dry-run or evaluation mode on the volume.
enable-paused - Anti-ransomware is paused on the volume.
disable-in-progress - Anti-ransomware disable work is in progress on the volume.
 [-dry-run-start-time <MM/DD/YYYY HH:MM:SS>]- Dry Run Start Time-
If this parameter is specified, the command displays the dry run start time of the volumes that have the state dry-run or dry-run-paused.
 [-attack-probability {none|low|moderate|high}]- Attack Probability-
If this parameter is specified, the command displays information only about the volumes that have the specified probability. The possible values are
none,low,moderate, andhigh.-
none - No data is suspected for ransomware activity.
low - Small amount data is suspected for ransomware activity.
moderate - Moderate amount of data is suspected for ransomware activity.
high - Large amount data is suspected for ransomware activity.
 [-attack-timeline <MM/DD/YYYY HH:MM:SS>,…]- Attack Timeline-
If this parameter is specified, the command displays information only about the volumes that have the specified attack-timeline.
 [-no-of-attacks <integer>]- Number of Attacks-
This provides the number of ransomware attacks observed.
The following example shows a sample output for this command:
cluster1::> security anti-ransomware volume show Vserver Volume State ---------- ------------ ------- vs1 vol1 enabled
