security anti-ransomware volume show
Show anti-ransomware related information of volumes
The security anti-ransomware volume show command displays information related to Anti-ransomware on the volumes in the cluster. The following information is displayed:
Vserver Name: The Vserver on which the volume is located.
Volume Name: The volume name
State: The Anti-ransomware state of the volume. The possible values are
disabled,enabled,dry-run,dry-run-paused,enable-pausedanddisable-in-progress.
[-fields <fieldname>,…] -
If you specify the
[-attack ] -
If this parameter is specified, ransomware attack details are displayed.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
If this parameter and the
-volumeparameter are specified, the command displays detailed information related to Anti-ransomware about the specified volume. If this parameter is specified by itself, the command displays information related to the Anti-ransomware about all volumes on the specified Vserver. [-volume <volume name>]- Volume Name-
-vserverparameter are specified, the command displays detailed information related to Anti-ransomware about the specified volume. If this parameter is specified by itself, the command displays information related to the Anti-ransomware about all volumes matching the specified name. [-state {disabled|enabled|dry-run|paused|dry-run-paused|enable-paused|disable-in-progress}]- State-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified Anti-ransomware state. The possible values are
disabled,enabled,dry-run,dry-run-paused,enable-pausedanddisable-in-progress. The possible states are:-
disabled - Anti-ransomware is disabled on the volume.
enabled - Anti-ransomware is enabled on the volume.
dry-run - Anti-ransomware is enabled in the dry-run or evaluation mode on the volume.
dry-run-paused - Anti-ransomware is paused from dry-run or evaluation mode on the volume.
enable-paused - Anti-ransomware is paused on the volume.
disable-in-progress - Anti-ransomware disable work is in progress on the volume.
[-dry-run-start-time <MM/DD/YYYY HH:MM:SS>]- Dry Run Start Time-
If this parameter is specified, the command displays the dry run start time of the volumes that have the state dry-run or dry-run-paused.
[-attack-probability {none|low|moderate|high}]- Attack Probability-
If this parameter is specified, the command displays information only about the volumes that have the specified probability. The possible values are
none,low,moderate, andhigh.-
none - No data is suspected for ransomware activity.
low - Small amount data is suspected for ransomware activity.
moderate - Moderate amount of data is suspected for ransomware activity.
high - Large amount data is suspected for ransomware activity.
[-attack-timeline <MM/DD/YYYY HH:MM:SS>,…]- Attack Timeline-
If this parameter is specified, the command displays information only about the volumes that have the specified attack-timeline.
[-no-of-attacks <integer>]- Number of Attacks-
This provides the number of ransomware attacks observed.
[-attack-detected-by <anti_ransomware_detection_type>]- Attack Detected By-
If this parameter is specified, the command displays information only about the volumes that have the specified attack detection type. The possible values are
file,block.-
file_analysis - Attack is detected by file activity analysis.
encryption_percentage_analysis - Attack is detected by data encryption percentage.
[-block-device-detection-status <arw_block_device_detection_status>]- Block Device Detection Status-
If this parameter is specified, the command displays information only about the volumes that have the specified block device detection status. The possible values are:
evaluation_period - Attack detection is currently in its evaluation phase.
active_unsuitable_workload - Attack detection is active, but the current workload is not suitable for Anti-ransomware protection.
active_suitable_workload - Attack detection is active, and the current workload is appropriate for Anti-ransomware protection.
[-block-device-evaluation-start-time <MM/DD/YYYY HH:MM:SS>]- Block Device Evaluation Start-time-
If this parameter is specified, the command displays information only about the volumes that have the specified evaluation start time..
The following example shows a sample output for this command:
cluster1::> security anti-ransomware volume show Vserver Volume State ---------- ------------ ------- vs1 vol1 enabled
