Command reference
security anti-ransomware volume show
Show anti-ransomware related information of volumes
The security anti-ransomware volume show command displays information related to Anti-ransomware on the volumes in the cluster. The following information is displayed:
  • Vserver Name: The Vserver on which the volume is located.
  • Volume Name: The volume name
  • State: The Anti-ransomware state of the volume. The possible values are disabled , enabled , dry-run , dry-run-paused , enable-paused and disable-in-progress .
{ [-fields <fieldname>,…​]
| [-attack ]
If this parameter is specified, ransomware attack details are displayed.
| [-clear-suspect-status ]
If this parameter is specified, the command displays the progress of the clear suspect operation. This option will not display clear suspect operation progress for volumes that do not have junction-path set.
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
If this parameter and the -volume parameter are specified, the command displays detailed information related to Anti-ransomware about the specified volume. If this parameter is specified by itself, the command displays information related to the Anti-ransomware about all volumes on the specified Vserver.
[-volume <volume name>] - Volume Name
If this parameter and the -vserver parameter are specified, the command displays detailed information related to Anti-ransomware about the specified volume. If this parameter is specified by itself, the command displays information related to the Anti-ransomware about all volumes matching the specified name.
[-state {disabled|enabled|dry-run|paused|dry-run-paused|enable-paused|disable-in-progress}] - State
If this parameter is specified, the command displays information only about the volume or volumes that have the specified Anti-ransomware state. The possible values are disabled , enabled , dry-run , dry-run-paused , enable-paused and disable-in-progress . The possible states are:
  • disabled - Anti-ransomware is disabled on the volume.
  • enabled - Anti-ransomware is enabled on the volume.
  • dry-run - Anti-ransomware is enabled in the dry-run or evaluation mode on the volume.
  • dry-run-paused - Anti-ransomware is paused from dry-run or evaluation mode on the volume.
  • enable-paused - Anti-ransomware is paused on the volume.
  • disable-in-progress - Anti-ransomware disable work is in progress on the volume.
[-attack-probability {none|low|moderate|high}] - Attack Probability
If this parameter is specified, the command displays information only about the volumes that have the specified probability. The possible values are none ,low , moderate , and high .
  • none - No data is suspected for ransomware activity.
  • low - Small amount data is suspected for ransomware activity.
  • moderate - Moderate amount of data is suspected for ransomware activity.
  • high - Large amount data is suspected for ransomware activity.
[-attack-timeline <MM/DD/YYYY HH:MM:SS>,…​] - Attack Timeline
If this parameter is specified, the command displays information only about the volumes that have the specified attack-timeline.
[-no-of-attacks <integer>] - Number of Attacks
This provides the number of ransomware attacks observed.
[-attack-detected-by <anti_ransomware_detection_type>] - Attack Detected By
If this parameter is specified, the command displays information only about the volumes that have the specified attack detection type. The possible values are file , block .
  • file_analysis - Attack is detected by file activity analysis.
  • encryption_percentage_analysis - Attack is detected by data encryption percentage.
[-block-device-detection-status <arw_block_device_detection_status>] - Block Device Detection Status
If this parameter is specified, the command displays information only about the volumes that have the specified block device detection status. The possible values are:
  • evaluation_period - Attack detection is currently in its evaluation phase.
  • active_unsuitable_workload - Attack detection is active, but the current workload is not suitable for Anti-ransomware protection.
  • active_suitable_workload - Attack detection is active, and the current workload is appropriate for Anti-ransomware protection.
[-block-device-evaluation-start-time <MM/DD/YYYY HH:MM:SS>] - Block Device Evaluation Start-time
If this parameter is specified, the command displays information only about the volumes that have the specified evaluation start time.
[-clear-suspect-start-time <MM/DD/YYYY HH:MM:SS>] - Clear Suspect Start Time
If this parameter is specified, the command displays information only about the volumes that have the specified clear suspect start time.
[-clear-suspect-phase <arp_command_op_status>] - Clear Suspect Phase
If this parameter is specified, the command displays information only about the volumes that have the specified clear suspect phase.
The following example shows a sample output for this command:
cluster1::> security anti-ransomware volume show
Vserver    Volume       State
vs1        vol1         enabled
