vserver iscsi delete
Delete a Vserver’s iSCSI service
This command deletes the iSCSI service from a Vserver.
You must first disable the service with the command vserver iscsi modify with "-status-admin down" before you can delete the service. |
-vserver <Vserver Name>
- Vserver-
Specifies the Vserver for the iSCSI service.
cluster1::> vserver iscsi delete -vserver vs_1
Deletes the iSCSI service for Vserver vs_1.
