Command reference
vserver iscsi delete
Delete a Vserver's iSCSI service
This command deletes the iSCSI service from a Vserver.
Note You must first disable the service with the command vserver iscsi modify with "-status-admin down" before you can delete the service.
-vserver <Vserver Name> - Vserver
Specifies the Vserver for the iSCSI service.
cluster1::> vserver iscsi delete -vserver vs_1
Deletes the iSCSI service for Vserver vs_1.
