The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver iscsi delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a Vserver's iSCSI service
This command deletes the iSCSI service from a Vserver.
You must first disable the service with the command vserver iscsi modify with "-status-admin down" before you can delete the service. |
-vserver <Vserver Name>
- Vserver-
Specifies the Vserver for the iSCSI service.
cluster1::> vserver iscsi delete -vserver vs_1
Deletes the iSCSI service for Vserver vs_1.
