vserver vscan on-demand-task report delete
PDF of this doc site
Creating your file...
Your file is ready
Delete an On-Demand report
The vserver vscan on-demand-task report delete
command deletes an On-Demand report.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver from which you want to delete an On-Demand report.
-task-name <text>
- Task Name-
This parameter specifies the name of the On-Demand task whose report you want to delete.
-report-file <text>
- Report File Path-
This parameter specifies the path of the report-file whose report record you want to delete.
[-delete-report-file {true|false}]
- Delete Report File Also-
This parameter specifies if the corresponding report file is also to be deleted. By default, it is false.
The following example deletes only On-Demand report record:
cluster1::> vserver vscan on-demand-task report delete -vserver vs1 -task-name t1 -report-file /rep/avod_146_20150902_161439.log cluster1::> vserver vscan on-demand-task report delete -vserver vs1 -task-name t1 -report-file /rep/avod_146_20150902_161439.log There are no entries matching your query.
The following example deletes an On-Demand report file along with the report record:
cluster1::> vserver vscan on-demand-task report delete -vserver vs1 -task-name t1 -report-file /rep/avod_146_20150902_161439.log -delete-report-file true cluster1::> vserver vscan on-demand-task report delete -vserver vs1 -task-name t1 -report-file /rep/avod_146_20150902_161439.log -delete-report-file true There are no entries matching your query.
