security multi-admin-verify rule delete
Delete a rule
The security multi-admin-verify rule delete
command deletes the specified rule.
-vserver <vserver>
- Vserver-
This specifies the Vserver information to which the rule is associated with. This is an optional parameter. This parameter defaults to a Cluster server and supports only Cluster servers.
-operation <text>
- Operation-
This specifies the ONTAP operation whose associated rule is to be deleted.
The following example deletes the rule for ONTAP operation volume delete and the default Vserver cluster1:
cluster1::> security multi-admin-verify rule delete -operation "volume delete"
