      security multi-admin-verify rule delete
Delete a rule
The security multi-admin-verify rule delete command deletes the specified rule.
- -vserver <vserver>- Vserver
This specifies the Vserver information to which the rule is associated with. This is an optional parameter. This parameter defaults to a Cluster server and supports only Cluster servers.
- -operation <text>- Operation
This specifies the ONTAP operation whose associated rule is to be deleted.
The following example deletes the rule for ONTAP operation volume delete and the default Vserver cluster1:
cluster1::> security multi-admin-verify rule delete -operation "volume delete"
 PDFs
PDFs
