The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security multi-admin-verify rule delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a rule
The security multi-admin-verify rule delete
command deletes the specified rule.
-vserver <vserver>
- Vserver-
This specifies the Vserver information to which the rule is associated with. This is an optional parameter. This parameter defaults to a Cluster server and supports only Cluster servers.
-operation <text>
- Operation-
This specifies the ONTAP operation whose associated rule is to be deleted.
The following example deletes the rule for ONTAP operation volume delete and the default Vserver cluster1:
cluster1::> security multi-admin-verify rule delete -operation "volume delete"
