snaplock compliance-clock initialize
Initializes the node ComplianceClock
` snaplock compliance-clock initialize` command is used to initialize System ComplianceClock from the system clock. User should ensure that the system clock is correct before initializing the System ComplianceClock. System ComplianceClock can be initialized multiple times as long as all nodes in the cluster are healthy, all volumes are in online state, no volumes are present in the volume recovery queue and there are no SnapLock volumes or volumes with "snapshot-locking-enabled" parameter set to true or S3 buckets with object locking enabled.
-node {<nodename>|local}- Node-
Specifies the name of the node on which System ComplianceClock needs to be initialized.
[-force <true>]- Forces Initialization-
If you use this parameter, it will suppress the warning message during
snaplock compliance-clock initializeoperation.
cluster-1::> snaplock compliance-clock initialize -node node1
Warning: You are about to initialize the secure ComplianceClock of the node
node1 to the current value of the node's system clock. This
procedure can be performed only once on a given node, so you should
ensure that the system time is set correctly before proceeding.
The current node's system clock is: Wed Nov 26 16:18:30 IST 2014
Do you want to continue? {y|n}: y
cluster-1::>
