ONTAP commands
snaplock compliance-clock initialize
Initializes the node ComplianceClock
` snaplock compliance-clock initialize` command is used to initialize System ComplianceClock from the system clock. System ComplianceClock can be initialized only once by the user. Once initialized, user cannot make any changes to the System ComplianceClock. Hence, user should ensure that system clock is correct before initializing the System ComplianceClock.
-node {<nodename>|local} - Node
Specifies the name of the node on which System ComplianceClock needs to be initialized.
[-force <true>] - Forces Initialization
If you use this paramter, it will suppress the warning message during snaplock compliance-clock initialize operation.
cluster-1::> snaplock compliance-clock initialize -node node1
Warning: You are about to initialize the secure ComplianceClock of the node
         node1 to the current value of the node's system clock. This
         procedure can be performed only once on a given node, so you should
         ensure that the system time is set correctly before proceeding.
         The current node's system clock is: Wed Nov 26 16:18:30 IST 2014
Do you want to continue? {y|n}: y
cluster-1::>
