snaplock compliance-clock initialize
Initializes the node ComplianceClock
` snaplock compliance-clock initialize` command is used to initialize System ComplianceClock from the system clock. System ComplianceClock can be initialized only once by the user. Once initialized, user cannot make any changes to the System ComplianceClock. Hence, user should ensure that system clock is correct before initializing the System ComplianceClock.
-node {<nodename>|local}
- Node-
Specifies the name of the node on which System ComplianceClock needs to be initialized.
[-force <true>]
- Forces Initialization-
If you use this paramter, it will suppress the warning message during
operation.
cluster-1::> snaplock compliance-clock initialize -node node1 Warning: You are about to initialize the secure ComplianceClock of the node node1 to the current value of the node's system clock. This procedure can be performed only once on a given node, so you should ensure that the system time is set correctly before proceeding. The current node's system clock is: Wed Nov 26 16:18:30 IST 2014 Do you want to continue? {y|n}: y cluster-1::>
