vserver cifs domain name-mapping-search add
Add to the list of trusted domains for name-mapping
The vserver cifs domain name-mapping-search add command adds one or more trusted domains to the list of trusted domains to be used in preference to all others by the specified Vserver for looking up Windows user names when performing Windows user to UNIX user name-mapping. If a list already exists for the specified vserver, the new list is merged with the existing list. This command is not supported for workgroup CIFS servers.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver for which you want to add trusted domains.
-trusted-domains <domain name>,…​ - Trusted Domains
This parameter specifies a comma-delimited list of fully-qualified domain names of the trusted domains for the home domain.
The following example adds two trusted domains (cifs1.example.com and cifs2.example.com) to the preferred list used by Vserver vs1:
cluster1::> vserver cifs domain name-mapping-search add -vserver vs1 -trusted-domains cifs1.example.com, cifs2.example.com
