system services ndmp show
(DEPRECATED)-Display NDMP service configuration
|  | This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of Data ONTAP. Use the Vserver-aware "vserver services ndmp show " command. |
The system services ndmp show command displays the following information about the NDMP configuration across all the nodes in the cluster:
Node name
Whether NDMP is enabled on the node
Whether sending the NDMP password in clear text is enabled on the node
NDMP user ID
A combination of parameters can be optionally supplied to filter the results based on specific criteria.
- { [-fields <fieldname>,…]
If this parameter is specified, the command displays only the fields that you specify.
- | [-instance ]}
If this parameter is specified, the command displays detailed information about all entries.
- [-node {<nodename>|local}]- Node
Selects information about the specified node.
- [-enable {true|false}]- NDMP Service Enabled
Selects information about the nodes where NDMP is enabled/disabled.
- [-clear-text {true|false}]- Allow Clear Text Password
Selects information about the nodes whose clear-text setting matches the specified value.
- [-user-id <text>]- NDMP User ID
Selects information about the nodes that have the specified NDMP user ID.
The following example displays information about the NDMP configuration of all nodes in the cluster:
cluster1::> system services ndmp show Node Enabled Clear Text User ID ----------- --------- ----------- ------- node0 true true ndmp node1 true true ndmp node2 true true ndmp node3 true true ndmp 4 entries were displayed.
 PDFs
PDFs
