Command reference
system services ndmp show
(DEPRECATED)-Display NDMP service configuration
Note This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of ONTAP. Use the Vserver-aware "vserver services ndmp show " command.
The system services ndmp show command displays the following information about the NDMP configuration across all the nodes in the cluster:
  • Node name
  • Whether NDMP is enabled on the node
  • Whether sending the NDMP password in clear text is enabled on the node
  • NDMP user ID
A combination of parameters can be optionally supplied to filter the results based on specific criteria.
{ [-fields <fieldname>,…​]
If this parameter is specified, the command displays only the fields that you specify.
| [-instance ] }
If this parameter is specified, the command displays detailed information about all entries.
[-node {<nodename>|local}] - Node
Selects information about the specified node.
[-enable {true|false}] - NDMP Service Enabled
Selects information about the nodes where NDMP is enabled/disabled.
[-clear-text {true|false}] - Allow Clear Text Password
Selects information about the nodes whose clear-text setting matches the specified value.
[-user-id <text>] - NDMP User ID
Selects information about the nodes that have the specified NDMP user ID.
The following example displays information about the NDMP configuration of all nodes in the cluster:
cluster1::> system services ndmp show
Node        Enabled   Clear Text  User ID
node0       true      true        ndmp
node1       true      true        ndmp
node2       true      true        ndmp
node3       true      true        ndmp
4 entries were displayed.
