system services ndmp show
(DEPRECATED)-Display NDMP service configuration
This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of Data ONTAP. Use the Vserver-aware "vserver services ndmp show " command. |
The system services ndmp show
command displays the following information about the NDMP configuration across all the nodes in the cluster:
Node name
Whether NDMP is enabled on the node
Whether sending the NDMP password in clear text is enabled on the node
NDMP user ID
A combination of parameters can be optionally supplied to filter the results based on specific criteria.
[-fields <fieldname>,…]
If this parameter is specified, the command displays only the fields that you specify.
[-instance ]
If this parameter is specified, the command displays detailed information about all entries.
[-node {<nodename>|local}]
- Node-
Selects information about the specified node.
[-enable {true|false}]
- NDMP Service Enabled-
Selects information about the nodes where NDMP is enabled/disabled.
[-clear-text {true|false}]
- Allow Clear Text Password-
Selects information about the nodes whose clear-text setting matches the specified value.
[-user-id <text>]
- NDMP User ID-
Selects information about the nodes that have the specified NDMP user ID.
The following example displays information about the NDMP configuration of all nodes in the cluster:
cluster1::> system services ndmp show Node Enabled Clear Text User ID ----------- --------- ----------- ------- node0 true true ndmp node1 true true ndmp node2 true true ndmp node3 true true ndmp 4 entries were displayed.
