The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs users-and-groups remove-stale-records
PDF of this doc site
Creating your file...
Your file is ready
Delete the Stale CIFS local users-and-groups records for the specified vserver
The vserver cifs users-and-groups remove-stale-records
command removes Stale local users and groups entries associated with old CIFS server.
-vserver <vserver>
- Vserver (privilege: advanced)-
The command deletes Stale local users and groups entries associated with the specified Vserver.
The following example displays the syntax of the command.
cluster1::*> vserver cifs users-and-groups remove-stale-records -vserver vs1
