network bgp defaults modify
- PDF of this doc site
Creating your file...
Your file is ready
Modify BGP defaults
The network bgp defaults modify
command modifies the global defaults for border gateway protocol (BGP) configurations.
[-asn <integer>]
- Autonomous System Number-
This parameter specifies the autonomous system number (ASN). The ASN attribute is a positive integer. It should typically be chosen from RFC6996 "Autonomous System (AS) Reservation for Private Use", or the AS number assigned to the operator's organization. The default ASN is 65501.
[-hold-time <integer>]
- Hold Time-
This parameter specifies the hold time in seconds. The default value is 180.
cluster1::> network bgp defaults modify -asn 20
