The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver iscsi connection shutdown
PDF of this doc site
Creating your file...
Your file is ready
Shut down a connection on a node
This command shuts down a specified iSCSI connection within a session. If you want to shut down all iSCSI connections in a session, use the vserver iscsi session shutdown command.
-vserver <Vserver Name>
- Vserver (privilege: advanced)-
Specifies the Vserver.
-tpgroup <text>
- Target Portal Group (privilege: advanced)-
Specifies the target portal group that contains the connection you want to shut down.
-tsih <integer>
- Target Session ID (privilege: advanced)-
Specifies the target session ID that you want to shut down.
-connection-id <integer>
- Connection ID (privilege: advanced)-
Specifies the connection ID that you want to shut down.
cluster1::*> vserver iscsi connection shutdown -vserver vs_1 -tpgroup tpgroup_1 -tsih 4 -connection-id 0
Forces the shutdown of an iSCSI connection with the connection ID of 0 on Vserver vs_1 in tpgroup tpgroup_1, target session ID 4.
