ONTAP commands
security session limit delete
Delete default session limit
This command allows deletion of a default management session limit.
-interface {cli|ontapi|rest} - Interface
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-category {application|location|request|user|vserver} - Category
The session type for this default limit. The following categories are supported: application, location, request, user, Vserver.
The following example illustrates deleting all default limits for CLI management sessions.
cluster1::> security session limit delete -interface cli -category *
3 entries were deleted.
